9-Bolt hub adapters
JD A
08-12-2006 14:44:06
I need a set of 9-bolt hub adapters for my A.
39 A
08-12-2006 17:53:14
 Re: 9-Bolt hub adapters in reply to JD A, 08-12-2006 14:44:06
depending on the year of your A they may be easy to find or nearly Impossible to find, if you have 15 spline rear axels they can be found fairly easy, just look at wanted adds and such, if you have 12 spline axels they are not usually available, but you can replace the bull gears and axels fairly easily with the later 15 spline axels
JD A
08-12-2006 18:14:15
 Re: 9-Bolt hub adapters in reply to 39 A, 08-12-2006 17:53:14
50' A they are 15 spline
39 A
08-13-2006 06:13:07
 Re: 9-Bolt hub adapters in reply to JD A, 08-12-2006 18:14:15
They shouldn't be too hard to come by then, try some parts places that part out tractors they probably have them in stock
Richard Reed
08-12-2006 16:36:52
You only need the 9 bolt hubs and locking collars. The Mod. "A" John Deere did not require adaapters. They are on ebay from time to time, or try looking at some of the many places that are selling two Cyl parts. Good luck
PS. The hubs for pressed steel 9 bolt wheels are completely different than for Cast center wheels.
