HELP repair john deere 709 brush hog clutch
Vicky Mendoza
08-12-2006 11:06:53
I am writing for my hubby so be gentle on me. He is trying to replace the clutch on our JD 709 BH and he can't get it loose..He has loosened all bolts and such , he just can't get it to free up.He replaced it about 5yrs ago but can't remember how they did it.My grandfather helped then, he has passed now. Any help will greatly be appreacited.
Vicky
[email protected]
msb
08-12-2006 21:14:56
 Re: HELP repair john deere 709 brush hog clutch in reply to Vicky Mendoza, 08-12-2006 11:06:53
The one I have, you must remove the powershaft first.4-9/16 wrench sized cap screws --Then there is a nut in behind where the shaft wss bolted.Remove the nut and the whole clutch will slide forward, but its best to take the big adjustment at the rear off first.
Vicky Mendoza
08-19-2006 16:35:00
 Re: HELP repair john deere 709 brush hog clutch in reply to msb, 08-12-2006 21:14:56
Thanks Guys!!!! He finally got it.He was doing everything right, I guess it was just stuck. He has it back together now and it works but it starts to smoke after a bit and he tightens it more. What is making it do this? HELPPPPP its time to mow down the corn.
Thanks again
Vicky
Glen in TX
08-12-2006 16:44:44
You have put a bar in or something in the hole on top to hold the blade bar while turning and use the big wrench that came with shredder for clutch nut and put a long pipe on it to loosen the clutch nut. Then after soaking the clutch with penetrating oil it should all slide off. Sometimes they get stuck on the gear box shaft splines and you have to heat the hub or maybe even torch it off. I had to torch one off a Rhino shredder gear box 2 years ago. For it I got the clutch assembly a lot cheaper from a TISCO dealer. He can view the 709 parts catalog at JD parts online and see what it has for a clutch. Also find TISCO dealers for aftermarket parts at http://www.woodsonline.com or other aftermarket parts at aiproducts.com and dealer locator also. I might have a 709 manual and if so I'll post back later.
HTR
08-12-2006 11:54:37
There was three different clutches used on the 709 chopper. The old one was held on with a nut on the front of the gear box shaft. One had a set screw, and one had a snap coupler. Go to this link, type in 709 for the model, and do an alphabetical search for clutch.
Glen in TX
08-12-2006 16:45:52
 Re: HELP repair john deere 709 brush hog clutch in reply to HTR, 08-12-2006 11:54:37
Title says a brush hog ?? Like a shredder not a chopper.
HTR
08-12-2006 18:52:51
 Re: HELP repair john deere 709 brush hog clutch in reply to Glen in TX, 08-12-2006 16:45:52
OK, if we are going to pick on the nomenclature, John Deere calls them rotary cutters. Brush hog is slang for this type cutter.People in our area call them stalk choppers. Comes from when corn stalks were chopped, after picking corn,so they would have a better chance of decaying.
The page I linked is the parts catalog, without going through the parts home page.
Bob
08-12-2006 11:29:10
Is it rusted solid to the input shaft on the gearbox?
