JD 50 Value
chadah
08-12-2006 10:58:56
Look at a JD 50. Looks like a rod broke and put a hole through the main case between the engine and transmission, broke the cam and cam gear. Not sure about block and head. Hood looks in good shape, front nose cone dented up some. Narrow front, has been sitting outside uncovered for about 5-10 years, tires are probably no good.
No power steering.
About and 10 miles from me.
What do you guy think it's worth or what would be a good offer?
Was thinking about fixing it up, or just better to keep looking?
Did they make a 50 with power steering?
j cook (iowa)
08-13-2006 16:25:07
 Re: JD 50 Value in reply to chadah, 08-12-2006 10:58:56
Power steering became available about April, 1954 for the 50, 60 and 70 tractors.
This particular tractor sounds to me like it's a parts tractor, and not a very good one at that! The amount of things that you would need to fix or replace would be extensive and those parts won't come cheap. This one sounds like a money pit, and there is generally speaking nothing that special about a 50. If it was an all fuel 530, your "budget" to fix it might be substantially better, but this one is IMO a bad idea! Sorry!
Mike Aylward
08-12-2006 14:29:53
Chadah, I would say this 50 is a parts tractor at best. And it sounds like a lot of the good pieces might already be damaged so buy it accordingly. A few hundred would be about all a person could realistically put in it and come out on it. Find another 50 that needs a few things and use this one for a donor. Mike
uoflncolts
08-12-2006 11:45:04
I would say no more than $750 at the very most. Sitting outside that many years hurts it a lot. What shape are the rims in? If I looking at this tractor, I would look at how much you can get for it in parts off of eBay and offer a little less. Fixing up a 50 in that condition would cost more than getting a good used one. If it has broke the camshaft, it probably damaged the crank in some way and messed the oil pump/ pump shaft/ oil lines.
Ryan
