39B Gas Tank Removal
Woodie in TX
08-12-2006 09:32:04
I�m going to remove the gas tank from my 39B. It looks like I have to remove the steering column so I can lift the hood up over the exhaust and air intake stacks so I can get to the tank. To get the steering column out it looks like I have to pull it out the front of the tractor, through a lot of steering gear grease. Is this correct?
Mike M
08-14-2006 12:29:48
 Re: 39B Gas Tank Removal in reply to Woodie in TX, 08-12-2006 09:32:04
A word of caution on installing that worm shaft. Be careful to keep an eye on that upper bearing so it doesn't catch the gear and get bent up. It needs to be slid up past first.
van robinson
08-13-2006 20:16:58
i had to remove the tank on my '40 B just the other day. I had to remove the steering wheel. Then remove the medallion on the front of the tractor. The side curtains must be removed also. Remove the front cap on the steering gearbox and the top cap. removing the top cap helps you see what is going on. After those are removed, turn the steering wheel so the worm gear will slide off of the sector gear. Then pull the whole steering shaft out. Now, you can lift the hood and tank off. It is easier to take the hood and tank off together and put hood and tank back on together. I tried to put tank on tractor then hood. Kinda hard. But, put the tank on the hood then hood on tractor and it was much easier.
Van Robinson
P Browning
08-12-2006 10:50:36
Woodie in TX -- If you have access to Field Service Bulletin 142-S (2/15/43), page 1 illustrates how to remove fuel tanks from general purpose tractors (A, B, G & H) without messing with the steering parts. And if you do not have this document, email me and I will send it to you. (PatB)
