3020 loader return line plumbing
Gary in TX
08-12-2006 08:45:32
Hey guys, I'm wanting to get a 2 spool valve rigged up to operate my 48 loader on my 3020. I have had it on a 4020 with the hyd. filter cover for the return line fitting on it. I was wondering if anyone knew of a good place to plumb in a return line from the 2 spool valve without going through the filter cover. I know I could probably take a look see for myself on the tractor but I thought I would pick yall's brains some on it. Many thanks!
Gary
Gerald J.
08-12-2006 09:38:53
 Re: 3020 loader return line plumbing in reply to Gary in TX, 08-12-2006 08:45:32
Deere sells a cover with a hole. It was first made for the 2640. It is supposed to fit the '20 perfectly. It is shapped so it keeps from squirting the oil directly at the filter element.
Since the filter cover on my 4020 was thick aluminum, I drilled and tapped it 1/2" pipe thread. I've not looked at the filter element to see if that has caused damage.
Returning to the oil filter cover is Deere's practice.
Gerald J.
Woodbutcher
08-12-2006 09:02:53
Gary,
Bob is probably right about the filter housing as the best location. I put a front-loader on my 3010, though, and I ran the return to a plug on the back of the transmission housing above the hydraulic connections. It seems to work well there.
Butch
Bob
08-12-2006 09:18:28
 Re: 3020 loader return line plumbing in reply to Woodbutcher, 08-12-2006 09:02:53
Doing that simply dumps the oil back into the transmission housing, without cooling it, or filtering it, and it does not get added to the flow to the front pump.
When you depress the clutch, the transmission pump/charge pump stops, and you will run out of function oil WAY quicker dumping it back to the sump that way, instead of returning it to the front pump charge circuit.
Bob
08-12-2006 08:58:02
What's wrong with the returning it to the filter cover on the 3020, like you did on the 4020?
That gets the return oil where it needs to be, ahead of the filter, and in the return circuit, to the oil cooler and front pump.
