41 B front wheels and tires???
johnsdeere
08-11-2006 12:15:35
I have a 1941 B what what size tire and how wide of wheel should this have, I have a 550 16in on it now and it only has 1/8 in of clearance to the top. Should it have 15in rims?
Duane Larson
08-11-2006 19:43:17
 Re: 41 B front wheels and tires??? in reply to johnsdeere, 08-11-2006 12:15:35
johnsdeere,
Your tractor came with the third version of AB1023R 15 x 3.00D front wheels for a 5.00x15 tire. The hub casting number is B918R. The wheels are non-reversible, have 4 slots, and 2 rivets hold each of four flutes on the center wheel to the rim, for a total of 8 rivets. There are 6 holes to bolt the wheel to the hub, plus an additional 3 holes in that bolt circle to hold weights. The wheels are not stamped with a part number. Be careful not to get reversible wheels as they will not work with your hubs. Bead-to-bead width is 3.00" and diameter is 15".
Norv
08-11-2006 12:41:04
My 40 B has 5.00 x 15 inch tires . it has the original rims on it. Norv
johnsdeere
08-11-2006 14:15:41
 Re: 41 B front wheels and tires??? in reply to Norv, 08-11-2006 12:41:04
makes sense, can you tell me how wide your rim is? The 16 in that is on it is 5 in wide and I bought 2 15 in that are 4 in wide. What is the correct width to use with the 500 x 15 in rim 4in or 5in? Thanks
Mike n Mo
08-11-2006 16:53:03
 Re: 41 B front wheels and tires??? in reply to johnsdeere, 08-11-2006 14:15:41
The 4 inch should be good to use with the 5.00X15 tires. Mike
