Hand Start Compression Test
jdjack
08-11-2006 04:12:04
What is the best way to check compression on a Hand start A?
What should the spec be, with alum. pistons, cold, wot?
Would pulling it give a better test?
730virgil
08-11-2006 09:37:03
 Re: Hand Start Compression Test in reply to jdjack, 08-11-2006 04:12:04
i went to an auction at kochs in richland center wi with my uncle they had either a john deere ar or d . a boy of 10-12 years old was with his dad and uncle one of the men tried the flywheel to start it . it was stuck . the guy on fly wheel almost fell on his butt . the kid said maybe it has really high compression pistons and you pull it to start it .
Duane Larson
08-11-2006 05:40:50
jdjack,
The only compression numbers published for A, B, G, D are for "rated" rpm - and for the A that is at 975 rpm, and for gas pistons the compression is given as 110 psi. Field Service Bulletins say to belt the engine to another tractor and run it at rated rpm, then measure the compression. Both spark plugs should be out, and the throttle wide open. The readings from each cylinder should be within 10%.
For later model tractors they also gave compression numbers for "motoring" rpm and those numbers are at starter cranking speed with a fully charged battery.
Only if you have a screw-in type compression tester would I try measuring it when pulling it, and it is hard to get the correct engine rpm.
