4020 and ditch cutter..Sickle?
Nylon
08-10-2006 20:58:17
Guys,
Need some advice again. I have a couple of ditches that need to get mowed but are steep enough that it blows my internal saftey valve on self preservation. I know center of gravity is pretty low but... only takes once. I started to cut at the bottom and worked my way up the slope thinking as I went my confidence would build. The second cut up, the 4020 slide sideways on the cut grass a bit and that was it for me. {18.4 x 34 on cut 6 foot wide blade grass..thick and slick) My neighbor took out the 460 and he cut it. he isnt as heavy and has narrower tires. He says he puts a foot up in the seat at the angle in case he has to jump. Whicjh I think is insane as at best I would be pretty ticked at myself trying to rebuild a tractor I rolled..if I lived.
So the point after this long intro is this. I have been looking for sickle bars to see if I could side cut from above and below to get most of it. There are a lot of 7 foots out there in a variety of models. I like the idea of a 9 foot as it can get out there a bit cause a 7 foot on 4020 wouldnt get out past rear wheels much. I have seen the offset ditch cutters and such but I want something I can attach quick... do the ditches probably 2wice a year and thats it. We have a ih pull stalk chopper that actually cuts nice but was thinking something in 3 point would give me better control. Also wondering about mid mount as there is that front pto. I forget again is that pto 540 or 1000 or does it match whatever is in the back pto slot. how many splines up front? Any way tips on which models and experience would be great...and of course a reasonably cheap cutter would be a plus..I am not going to dumpmore than $800 to mow the ditch.
Thanks,
John
Brian on river rd
08-18-2006 20:28:57
 Re: 4020 and ditch cutter..Sickle? in reply to Nylon, 08-10-2006 20:58:17
I have a 7 foot mid mount mower sitting in the shed that we have not used for a long time. We have it mounted on a 4010 and was a great unit as it was out in front and was easy to watch. call me at 815-670-5181. The sickle bar is located in northern Illinois.
JMS/MN
08-11-2006 07:21:54
I've seen double NH mowers on a couple trips out West- both pulled behind the tractor. I don't understand two comments below about the front pto. I've always believed that it runs only at 1000 rpm- that's what the op manual says, and has nothing to do with which stub is in the rear pto drive. The rear runs at different speeds because the two stubs have driven gears at different locations on the shaft, meshing with different drive gears inside the tractor.
jd40an
08-11-2006 09:09:36
 Re: 4020 and ditch cutter..Sickle? in reply to JMS/MN, 08-11-2006 07:21:54
I can assure you that that changing the rear stub shaft does indeed change the speed of the front shaft. At least on a 4010 it does.
Gerald J.
08-11-2006 20:10:32
 Re: 4020 and ditch cutter..Sickle? in reply to jd40an, 08-11-2006 09:09:36
The 4010 and 4020 PTOs are drastically different. The shifter pin on the 4010 with flanged stub shaft does shift the speed on both front and rear PTO. That's not the case with the 4020 and its inserted splined stub shaft. There the front always runs at 1000 rpm (when the engine is at PTO speed).
Gerald J.
JMS/MN
08-12-2006 09:17:13
 Re: 4020 and ditch cutter..Sickle? in reply to Gerald J., 08-11-2006 20:10:32
Thanks- that would explain it- I've had only 20 series and newer JD.
Nylon
08-11-2006 20:22:39
Gerald nailed it. I went out and pulled my front pto cover off and it is splined for 1000.
Thanks,
Gerald
jd40an
08-11-2006 05:32:00
I have used a #50 balanced head 9' side mount on a 4010D for many years. It's a great mower,a little difficult to mount, and when you have to rebuild the head, you'll have mower parts strewn all over your shop-not a fun job! Would I buy another? In a heartbeat! It drives off the front PTO, & you MUST have the 1000 RPM shaft installed at the rear, otherwise you can almost count the strokes! Overall, It's the easiest to operate mowing outfit, I've ever used.
Steve Crum
08-10-2006 21:48:43
We had a 3010D for years that we put a JD #10 mid mount 9' sickle bar mower on. This was belt driven from the front PTO. The sheive came with the mower and was 1000 rpm fine spline with a taperlok hub. I'm pretty sure this only ran 540 rpm as set to the speed of the rear shaft. Dad would have skinned me if I ran it at 1000 rpm.
This used the standard powertrol for raising and lowering and you could stand the bar straight up and trim hedgerows with it. A real slick rig. Dad paid $300 for it
Nylon
08-10-2006 22:18:45
 Re: 4020 and ditch cutter..Sickle? in reply to Steve Crum, 08-10-2006 21:48:43
that sounds like the ideal rig. I probably have a better chance of getting whacked by lightening than finding one of those. :]
Thanks for info
Steve Crum
08-11-2006 04:11:46
 Re: 4020 and ditch cutter..Sickle? in reply to Nylon, 08-10-2006 22:18:45
Naw just do some looking around. These were designed for the new gen tractors. So there's probably quite a few still out there.
