44 A engine size
jdjack
08-10-2006 15:01:36
How does the engine horse power from a 1944 A compre to a 1949 A?
If different what is different?
Thanks.
Steve Crum
08-11-2006 08:06:53
 Re: 44 A engine size in reply to jdjack, 08-10-2006 15:01:36
Probably the biggest difference is the 44'A is an all fuel configuration with lower compression and rated while running on fuel oil or distillate. Wheras most 49'As were gas only and employed higher compression and the cyclone concept in the head. Most if not all 49's used aluminum pistons at this point and other tech advancements and improvements in fuel and oil tecnologies developed during the war helped reduce some parasitic power losses and improve combustion and thus the increased power.
Mike M
08-11-2006 11:32:06
 Re: 44 A engine size in reply to Steve Crum, 08-11-2006 08:06:53
Aluminum pistons did not come out from JD at least until the models 50,60 later in production as the real early 50,60 still even had cast iron ones,but I think the ring grooves were narrower than the pistons in the A,B models.
sds46a
08-11-2006 02:12:29
From the JD HP guide on the left hand side of this site: 29.59/26.20 compared to 38.02/34.14
for the '49.
Doug
