JD 1010 lift question
Hobo,NC
08-10-2006 10:39:23
I got my grandpa�s 1956 JD 1010 run�in and want to go werk it with a JD disc turn�in plow, he died in 1975 and no one in the family know�s the answer, question izz. It has 2 position control leavers for the lift, would like info on how this set up izz spose to werk., Izz one for draft control if so I understand draft control but would need to know the position to run the leavers in to use draft, Thanks Hobo,NC
john-in-ga
08-11-2006 06:28:03
 Re: JD 1010 lift question in reply to Hobo,NC, 08-10-2006 10:39:23
You got a couple of answers over on the other board from a couple of fellows who�s advice I trust. ;>). I�m posting the same response there to correct a couple of typing errors I made over there. I�m also leaving out the reference to 8Ns, as that could cause confusion here. I also want to see if the information given is correct, as there surely is someone here how knows the correct procedure to adjust the lift on a 1010.
I�ve never been on a 1010 much less operated one, but I do have a John Deere with the two levers to control the functions of the lift. This is how I was told to set them. When setting up to plow, use the outside lever (it should be you depth control lever) to set the depth . Once you are fairly satisfied with that, pull the inside lever (it should be your draft control lever) up even with where you now have the depth control lever. Then use the depth control lever to raise and lower the implement. As I understand how it works, the inside lever is suppose to adjust how fast draft control responds to changing ground conditions. One more note. When the draft control lever is all the way down, your lift should be in the position control mode.
Hobo,NC
08-11-2006 20:00:06
 Re: JD 1010 lift question in reply to john-in-ga, 08-11-2006 06:28:03
thanks, I will make a werk'er out of it you kin bet on that.
wkk427
08-10-2006 19:26:57
i beleive that you could seperate the lift arms and lifteach one individual or hook them together and lift both at the same time
