JD 40 Distributor backwards?
Nipomo Steve
08-09-2006 21:29:36
Its time for my JD 40's first tune up since purchase because of rough running problems. The manual says the primary wire should go in the distributor away from the engine, but mine is against the engine. The plug wires are toward the front of the distributor which looks right, but how do I tell if the oil pump is out of time or if the previous owner left me a mess?
Also, how do you set up a timing light on this 6V tractor and what do you use for timing marks?
Nipomo Steve
08-12-2006 20:29:32
 Re: JD 40 Distributor backwards? in reply to Nipomo Steve, 08-09-2006 21:29:36
Thank you gentlemen. With a few new parts and the distributor still backwards, my 40 runs like new. I appreciate your input.
steve
Henry M
08-10-2006 06:13:12
Steve
I stuck my ancient timing light on the 420 that I had bought in the old days when you timed motors ( the timing light that is). It wouked fine on the 6 volts on the 420.
There should be two marks on the flywheel that you look at thru the peep hole. One shoul say DC - Ah ha, dead center, when the no one is up on tdc. The other should say spark. That is the mark that you time it to with a light with the throttle set at wide open (jd calls it fast idle)
I went thru that timing the oil pump issue with the 420. Yep the guy just slung the dist in there and screwed it around until he got the time where he wanted it. The dist will only drop onto the drive slot on the top of the oil pump shaft one way due to the slot being cut off center - murphy proof, like on the N series ford. timing the oil pump means having the shaft in a position so when you slide the pump drive gear up into the teeth on the cam shaft drive gear and later drop the dist in the dist will be in a clockwise position as you described.
So it sounds like the last guy just threw the oil pump in and then screwed the dist to a position where it would light the no one when it was in the correct position to fire. That should not make a difference on how the motor runs just on where the lead wire to the dist is when it is in time.
You have to drop the oil pan and the oil pump to unsquirrel how the distributor is aligned.
Make sure the advance moves easily. If not I would pull the dist and totally disassemble it and get the two shafts clean and free and oiled.
Whatever you do time it to the spark mark. When timing you should be able to watch the mark move as you throttle down until in most cases the tdc mark will show up when it is at idle and the timing is backed off by the advance, then it should smoothly advance up to the spark mark as you move the throttle to wide open.
Timing the oil pump procedure is in the 40 service manual so I can't help you on the wording from the manual since the 420 book referrs us to the 40 book.
Jason Mills
08-10-2006 05:25:08
Use a 12 V battery from another source and clamp the lead on the plug wire. You will have to open the little cover on the bellhousing behind the oil gauge. You may have to scrape paint to find the timing mark in the case. There are marks on the flywheel to time tractor by. May have to scratch for them too. Good luck, Jason.
bill mar
08-10-2006 03:55:05
dont know about the first part of your questions.but what would keep you from powering a 12 volt timing light from a seperate 12 volt automotive battery with only the sparkplug lead of the timing light hooked up to the tractor.bill m.
