A Clutch Knock
MDM
08-09-2006 20:41:56
I have a late styled A that has a knock in the clutch, with the lever pulled back and applying pressure on the pulley brake, you hear nothing, but when you release the pressure on the brake pad and slowly move the lever forward....you hear the knock....with the lever fully engaged you hear nothing..... any ideas???
Mike M
08-10-2006 05:59:59
 Re: A Clutch Knock in reply to MDM, 08-09-2006 20:41:56
Check for loose clutch driver and flywheel and set end play to .005-.010" A loose fylwheel can sometimes make noise at the clutch side.
