430 Hood Patch
PossumCop
08-09-2006 19:35:14
Hello all, I�m new to the forum and enjoying very much, a lot of good info here. I'm restoring a 430W and my hood is burned out on one side of the exhaust hole from a leak. I have seen hood patches for some of the older JD�s but not the 430�s. It can be fixed with bondo but not sure how it will hold up being that close to heat. Also the metal is rolled to the underside and may be hard to make it look original. Any Suggestions????? ???
Henry M
08-10-2006 06:22:39
 Re: 430 Hood Patch in reply to PossumCop, 08-09-2006 19:35:14
possum
The 420 has a heat shield spotted to the hood where the exhause heat hits, I don't know about the 430.
I have done some fender repairs with some (about .050 thick) sheet metal - I bought a square foot at the farm store since I did not have any in the scrap, welded it in the hole with the little wire welder and then when it came to make the roll - took out the torch and with it in one hand and the hammer in the other heated and shaped the roll. It did take a little filler for final appearance.
