70 diesel PTO runs all the time.
bdeerehunter
08-09-2006 14:41:28
My 70 diesel pto won"t disengage. The shifter handle is loose. I am sure that it is either loose or broken inside. WhatI would like to know is what is the best or only way to access it. Preferablly without disassembling the whole tractor! Thanks alot.
buckeye al
08-09-2006 15:37:46
 Re: 70 diesel PTO runs all the time. in reply to bdeerehunter, 08-09-2006 14:41:28
Since you say it runs all the time I'm assuming it is an engine driven or live PTO tractor and the handle that is loose is the handle on the side of the battery box.
It may just need to be adjusted but if it has operated like this for long, probably some new disks and the brake plate need to be replaced.
As long as the main drive train & master shifter are all OK, it is all repairable by only removing the rear cover of the live PTO clutch housing. I don't suggest tackling it without at least having access to a book! There were a couple different styles but the differences mostly surrounded the adjustment procedure and number of disks. They're not too bad to work on. Good number of pieces in there though.
Good luck.
bdeerehunter
08-10-2006 15:43:34
 Re: 70 diesel PTO runs all the time. in reply to buckeye al, 08-09-2006 15:37:46
I'm sorry I should have mentioned that it does not have live PTO and that the shifter is right beside the main shifter under the steering wheel. sorry for the confusion and thanks in advance.bdeerehunter
buckeye al
08-11-2006 14:33:23
 Re: 70 diesel PTO runs all the time. in reply to bdeerehunter, 08-10-2006 15:43:34
That one, I'll have to look up in my 70 shop manual. I've only worked on live PTO's.
bdeerehunter
08-11-2006 19:23:21
 Re: 70 diesel PTO runs all the time. in reply to buckeye al, 08-11-2006 14:33:23
That's what I keep hearing from all the sources that I have here in Tennessee! I have found out that there are not very many 70 diesels without live pto around here. I'm really stumped because my service manual does'nt even show the shifter for the tractors without live power
