520 Pistons
Andy Conner
12-08-1999 17:07:52
We need a set of .45 over pistons for our 520LP Does anyone out there have a suggestion on which direction to go? All tries so far have dead ended. What is plan "B" , bore the block & sleeve it?
Rob
12-09-1999 18:56:35
 Re: 520 Pistons in reply to Andy Conner, 12-08-1999 17:07:52
I found a company called Hinrich's Repair that sells Cleavite pistons. These are the same manufacturer of M&W pistons that Deere sold as replacements. Their number is 815-772-4513.
I've got a set in my "50" and they work fine.
Dan
12-08-1999 19:24:51
Polk has been pretty high for anything I have tried to get from them - found other suppliers that were much more reasonable price wise. Shorty Dear in Perryton Texas has been a good contact, and Two Cylinder Plus - David Marlin in Conway Missouri also. Check with them, Shorty has listings in the for sale ads of YTM, and Two Cylider Plus is 417-589-2634. Check all three and see what you find, good luck!
STMTS
12-08-1999 17:26:03
Boring and sleeving is probably the best route.It should cost about $250-300 to do it.About the same for pistons IF you could find any!Sleeves for a 6 3/4" D are $125 ea.A 520 is only 4 11/16 bore they shouldn't be more than $60-70 ea. plus machining to fit your pistons
Chuck
12-08-1999 17:32:39
 Re: Re: 520 Pistons in reply to STMTS, 12-08-1999 17:26:03
you might try Polk equipment...advertises in the Green Magazine...
