4020/148 loader - ldr slowly raises all the time
JAYFARMLAW
08-09-2006 13:54:43
I bought a 4020 that had been sitting for almost a year, it runs great and seems to be a good tractor. Then I put a 148 loader on it that had sat for a long time (2 years).
The problem is that the loader will slowly raise all the time the tractor is running. After about 2 minutes, the loader will be over your head. It works fine otherwise( up/down/tilt). you can also hear the hydraulic pump working all of the time.
I also put a baler on the other remote and the tailgate would try to raise on it too. both remotes have the problem, just the right side seems more severe.
slightly moving the remote lever will fix the problem so it seems like the remote levers need an adjustment....or the seals in my remote blocks need to be replaced since fluid is getting by.
What do you think??
Thanks in advance for your response,
Jay
JAYFARMLAW
08-21-2006 14:22:41
 Re: 4020/148 loader - ldr slowly raises all the t in reply to JAYFARMLAW, 08-09-2006 13:54:43
Anybody else????
Bob
08-09-2006 14:00:51
At the very least, the hydraulic valves in each block need to be set.
There could be valve or seat damage, too.
