JD B governor.. got one?
ARS
08-09-2006 06:30:53
i know that there is a for sale/wanted section, but i need a governor for my B ASAP. mine is completely shot inside and i have a show to go to in 2 weeks. i had a guy that sold me one but when he looked at it, it was junk also, so now i need one REALLY fast. its for a 1944 handstart JD B. someone please help me!
johns48b
08-09-2006 18:35:28
 Re: JD B governor.. got one? in reply to ARS, 08-09-2006 06:30:53
try marlyn smith in iowa at 712-489-2570. nice guy to deal with. he works for a trucking co and might get it to you pretty quick. i'm in n al so i don't know what he has on hand, but anything i ever needed for my 48b he had. good luck. haste makes waste by the way.
dab
08-09-2006 11:03:20
If you need one that fast try polks. I would think they have one. Where do you live? In northern Indiana there is a pretty big bone yard with a lot of row crop -B-s and -A-s in there.
ARS
08-09-2006 11:45:46
 Re: JD B governor.. got one? in reply to dab, 08-09-2006 11:03:20
i live in pa. i called polk and they want $275 for one... i think thats alittle too much
F-I-T
08-09-2006 11:54:24
 Re: JD B governor.. got one? in reply to ARS, 08-09-2006 11:45:46
Well it depends on how bad you want it. THey have, you don't.
What's wrong with yours? There's not a lot to go wrong that can't be fixed, unless it has a wallowed out thrust bearing area behind the mag.
ARS
08-09-2006 12:06:55
 Re: JD B governor.. got one? in reply to F-I-T, 08-09-2006 11:54:24
thats exactally what was bad on mine, the bearing surface behind the mag
Mike M
08-09-2006 13:07:32
 Re: JD B governor.. got one? in reply to ARS, 08-09-2006 12:06:55
If you have good gears then that worn housing is an easy fix. Two ways to do them 1 way I think is in the I & T book you cut some off the spring and coupling and put an extra bearing center race in for a spacer and move everything over to a new spot. The other one I have also used is to remachine the housing to accept a bushing. anyone with a milling machine should be able to do it for you. I'm willing to bet most all of the used ones are going to need fixed too.
F-I-T
08-09-2006 13:31:38
 Re: JD B governor.. got one? in reply to Mike M, 08-09-2006 13:07:32
Most of the governors I see these days require boring out and a sleeve inserted, and then bored to final dimension to make them servicable again. Not a tough job, but it can get pricey real fast if your machine shop is long on the set up time.
