620 hood
Craig T
08-08-2006 20:35:27
I'm an Farmall man and I know nothing about John Deeres. I have been working on my great grandpa's 620. We need to get the hoods off so we can weld on a broken cast iron piece. I was wondering how you get them off. It seems like a whole days work. Also, should we replace the diaphrams in the sediment bowl? Any input would be helpful. Thanks.
Pitalplace
08-09-2006 13:15:27
 Re: 620 hood in reply to Craig T, 08-08-2006 20:35:27
A crankcase full of gas is no fun, let alone the 5 gallons of fuel waisted. I would for sure change the diaphrams, the valve seat washer and screen. All can be had a JD cheap.
uoflncolts
08-08-2006 21:16:47
There are a lot of step to removing a hood. Take nose piece off, unbolt where the steering wheel rod goes into the pedestal (will have to remove steering wheel or seat to pull this out of the support column), remove choke rod by taking knob off, remove fuel line, unbolt the support from the govenor housing, unbolt hood bolts and it should come right off. I do not think I missed any thing but there could be a few other lines that you have to take off. What cast piece are you looking for, I might have an extra. On the diaphrams, order them at JD store and see if they can print you a copy of that page in the parts catalog or buy one while you are there.
Good Luck,
Ryan
