Inner wheel bearings/Pack?
Stewart Denney
08-08-2006 12:42:38
Aquired my Dad's old tractor, it's a 1948 JD mod.A, styled, per serial no. My question is on packing front wheel bearings, I don't have a repair manual yet, Could someone give me info on how to get the inner bearing out, does it come out? Took hub off of spindle, inside, took out two felt like seals, I haven't quite got everything cleaned up yet, it just doesn't look like seals on other wheels, like a car or truck or trailer. The metal part of what should be part of the seal is still inside. Any response would be greatly appreciated. Thank you.
Glen in TX
08-08-2006 16:30:35
 Re: Inner wheel bearings/Pack? in reply to Stewart Denney, 08-08-2006 12:42:38
The hub has a metal retainer D635R and uses 2 felt seals D636R in each retainer per hub. Pull the retainer out and then you can get the bearing out. If you damage the retainers new ones are still available as are the felts from a JD dealer. Your dealer prices may vary from these.
Part Details Part Number: D635R Part Price: 7.22 USD On Hand: 0 Check Other Stores Description: RETAINER, FRONT WHEEL FELT Part Number: D636R Part Price: 5.62 USD On Hand: 0 Check Other Stores Description: WASHER, FELT, GREASED
