B A Little Slow
Gr8Bald1
08-08-2006 12:24:29
On my 51 B's maiden voyage after complete rebuild(a tractor ride), I was only able to roll 11.5 MPH in 6th gear. I didn't put this thing together to run the Salt Flats, but if I remember from the manual she should be able to scoot down the road at 14 or 15. There were times I had trouble keeping up with my group in the 11-12 MPH group. It seems to run fine and the throttle linkages are adjusted to spec (with the throttle lever wide open with the tractor off, the carb linkage can't open any more). Where am I losing those 2-3 MPH?
Gr8Bald1
08-09-2006 01:22:55
 Re: B A Little Slow in reply to Gr8Bald1, 08-08-2006 12:24:29
Thanks for answering my question--the ride was at the end of June and I've been stewing over what I may have done wrong ever since. I have the manuals, I'm just really far from them. And CLW, you're probably right--I probably saw the stats for the hi-lo tranny and got that stuck in my head. Thanks again!
Rob
CLW
08-08-2006 19:27:41
I think you may be thinking of the 43-47 B with the hi-lo. They were faster than the late B. They ran about 15-16 as I recall.
Mike Aylward
08-08-2006 17:30:55
Gr8Bald1, at rated speed your B is supposed to run 10 mph. It sounds like you were rolling right along to get to 11.5. Mike
Scott's B haven
08-08-2006 17:09:26
My data book says 6th gear tops out at 10mph hope it helps.
