3020 rockshaft adjustment
gumba
08-08-2006 07:35:16
The three point hitch on my 3020 will only raise up a little way. Therefore, when I'm using it, the implement barely clears the ground. When I shove the lever to the up position I feel resistance only in the upper last half-inch, and it is in this 1/2 inch that the lift arms respond. I bought this tractor a year ago and it came with this problem. Any advise y'all?
msb
08-08-2006 21:27:15
 Re: 3020 rockshaft adjustment in reply to gumba, 08-08-2006 07:35:16
Where is your L&D set? Try it in D and see if it will raise all the way up.If not then adjust the cable length as described in the other posts.If it raises all the way up proceed with the next step.Then set the L&D lever in the middle slot. After completely lowering the arms,set the front or leading edge of the dash or console lever on 1.If you go past 1 drop it down and start over.Remove the bung hole plug at the rear of the seat.Tape or better yet, weld a 9/16" socket to a rod or extension bar about 18" long.Inside the bung hole is a nut that you unlock by putting the socket on it and pushing the nut back.Its a castle nut locked in place by a roll pin.With the engine idling and the 3 pt arms down,slowly turn the nut counterclockwise until the arms just begin to raise.Remove the socket and rod/extension bar.Push the raise/ lower lever all the way forward if an older tractor or rearward if a console model.Let it stabilize for a moment or two then very,very slowly move the lever in the opposite direction until the arms just begin to drop.The leading edge of the lever should be on 4 at that point if everything else is in adjustment.If the difference is closer that 1 & 4 readjust and split the difference on the adjustment.BE CAREFUL when adjusting the bung hole nut that you stay out of the way of the arms.CAUTION: IF you lose the socket in the rear end, it is VERY BAD NEWS!Takes a LOT of work to retreive it.
Glen in TX
08-08-2006 08:46:53
Spray penetrating cable lube on cable and ends also and if still binding might have to get a new cable. Soak it long enough and it might come loose enough to work for a while yet. Parts catalog at:
Gerald J.
08-08-2006 08:05:39
Take off the right seat shield and adjust the length of the three point cable connection to the rock shaft valve arm.
Gerald J.
JMS/MN
08-08-2006 11:29:32
 Re: 3020 rockshaft adjustment in reply to Gerald J., 08-08-2006 08:05:39
Isn't there also a cog setup inside the rockshaft housing that also slips out of adjustment?
Gerald J.
08-08-2006 15:05:54
 Re: 3020 rockshaft adjustment in reply to JMS/MN, 08-08-2006 11:29:32
Could be, if the shaft is turned too far. I found the adjustments needed were considerable while I was replacing the cable after it froze up spring before last. And I was able to adjust the link connecting at the valve for full 3 point motion, once I got the cable sheath anchors bolted down right.
I had to take the covers of the cowl, and lift the floor board besides taking off that right side seat shield.
Gerald J.
