more power!!!!
80 kid
08-07-2006 18:39:31
how can i get more HP out of my JOhn deere 80 by saterday for the tractor pull.... any help at all thanks...
gtx1967jewison
08-09-2006 09:25:43
 Re: more power!!!! in reply to 80 kid , 08-07-2006 18:39:31
find someone to help you turn up the pumps then just shift up 1 gear if traction becomes a problem. when someones tractor spins out in high gear then they have a traction problem. until then the problem is NEED MORE POWER.
buickanddeere
08-09-2006 13:56:21
 Re: more power!!!! in reply to gtx1967jewison, 08-09-2006 09:25:43
I would rather casually putt into one of the top three winners with a tractor that doesn't appear to be straining. That really ticks off the pullers with souped tractors that don't pull any farther.
80kid
08-08-2006 15:02:38
i guees i should ask is there a better way to keep my 80 on the ground... i have 18.4-34 on it and it weighs 9980... with me in the seat... i want it to smoke black longer than it dose it only does if the tires spin but that is it...
buickanddeere
08-07-2006 22:29:18
You can't stall it in 1st creeper gear even in the 12,000lb class on a power track. 1st gear standard should be good to 10,000lb except on the stickiest of tracks. There are three things to worry about before HP. Traction, traction and traction.
bm3501466
08-07-2006 20:01:46
What size tires are you running? You probably won't run out of power, you will just spin out. HP isn't everything. Of course it is nice to bore, stroke, port polish the heads and turn up the pumps, but it is all vain if you can't get the power to the ground.
