'50 A transmission gear tooth
njs
08-07-2006 11:23:14
One of the teeth on the 35 tooth side of the countershaft idler gear (A3803R) is 90% snapped off at a 45 degree angle. The "lead-in" is gone and there is only about 1/8 wide tooth left at the top opposite the engagement edge. Since I have never had this running, what does this cause?
Can one have this much tooth replaced by welding?
Many thanks!!
Pappy
08-07-2006 21:30:25
 Re: '50 A transmission gear tooth in reply to njs, 08-07-2006 11:23:14
It could be welded and re-machined by a good machine shop. My brother-in-law (now retired) says he used to do them frequently. Anyway, it won't be a cheap repair.
You might look around and find a good usable used one for less money. If you are using the tractor for light duty, either method should be good.
