JD 60 clutch question(s)
Jak
08-07-2006 10:25:19
I have a 60 at the shop that has a bad rattle in the clutch area.The dogs and toggles have been replaced,fork had been replaced.Clutch facing discs have been replaced as well as the metal discs.When engaged it is quiet but when it is disengaged it rattles loudly.It is louder than just worn friction discs like some I have heard.I am gonna put new bushings in it and a new bearing that resides in the clutch wheel.The gear on the clutch wheel has moved out a couple of times,this time we are gonna pin it or put some set screws in it.My question is:will having the pistons shaved off and having machined aluminum caps installed to make higher compression on them make a vibration in the clutch area that a stocker wouldn't have?I am trying to figure out this loud rattling.Have any of you had this before?Any info will help.Thanks,Jack(TN).
JDMAN60
08-08-2006 04:25:54
 Re: JD 60 clutch question(s) in reply to Jak, 08-07-2006 10:25:19
Jack I also have a 60 that had a loud rattle in the clutch. When I done the restoration in 2005 I looked into the rattle and found that some of the noise was coming from the small pin that is pressed into ths back of the belt pulley that keeps the actuating sleeve from turning. The hole in the sleeve was worn oblong and the pin showed some wear also. I took the sleeve off and had a machinist friend to bore it out a little oversize and then make a stepped pin that fit. Now the noise seems to gone . I hope this helps. William
G/MAN
08-07-2006 13:30:22
Modifying the pistons like that will throw the assembly out of balance, and could cause pre-existing wear and/or noise to get worse.
Jak
08-07-2006 13:46:23
 Re: JD 60 clutch question(s) in reply to G/MAN, 08-07-2006 13:30:22
Thats what I was thinking.It is loud and doesen't sound like the usual clutch drive gear/friction disc slack.I am gonna tear into it and see if I can help it.The owner bought brand new metal plates that fit between the clutch facings that have the teeth on them that spline to the drive disc.This tractor has always had clutch problems since the prior owner capped them pistons.It might not have nothing to do with the clanking but my eyebrows are raised.Something is making the clutch wheel drive gear walk out on the shaft for some crazy reason also??Oh well thanks for the replies fellas.I will keep ya posted on what I find.Tonight I have to paint some Farmall red,AAAARRRRGGGGH!I'll work on the good color tomorrow.LOL
G/MAN
08-10-2006 07:44:40
 Re: JD 60 clutch question(s) in reply to Jak, 08-07-2006 13:46:23
It's also possible that with the raised compression the engine is now "pinging" or going into preignition/detonation. This shock-loads the heck out of things and can lead to catastrophic engine failure if allowed to go on long enough.
Blksmok
08-07-2006 11:57:26
Jack...JD 60's are known for worn clutch drivers and worn crankshaft splines. Check the splines on both items for signs of wear. They do make undersized drivers that may fix the problem if that is where the "extra" noise is coming from.
machinery-man
08-07-2006 11:00:02
I would suspect the drive disc gear and drive plate is worn. When not engaged it can jerk around if there is excessive clearance.
machinery-man
08-07-2006 10:59:39
