1974 JD 140 H3 A321 I took the John Deere 140 H3 (A321) Tractor to the dealer because the Power Take Off would no engage. Two weeks, a new voltage regulator and $175 dollars later, it is done. So this Saturday morning I get up and proceed to cut the lawn. I get about 1/3 of the way through and she is running far too hot, white smoke is coming off the block and she's binding and stalling. I let her cool off and pull the mower deck, it's clear, blades turn freely by hand in sync. Check the PTO drive belt. It's smoked; I cooked it so I changed it out. Check the fluids and fire her back up. Runs like a top. Okay - get back to the lawn and engage the PTO. Same result. So I call the dealer and the service manager wants it back ASAP - "Don't run it. It�s binding somewhere. You want us to come get it?" It's now 12:00 and those guys are getting ready to head home for the weekend. The last thing some poor guy wants to do is drive over here from the dealership in the heat and humidity to pick up a 33 year old 140. "No, it's not that critical. I'll bring it by Monday." Actually, I could drop it off anytime and do so. So I get the tractor back - "... you did not have the drive belt tensioned to spec." "It's the same setting I use every time." (for the last 25 years) "Well, it was not right. It's covered in your user manual." (This tractor was purchased from this dealership when I was 7. What makes you think I have the 'user manual') "Uhmmm, okay." "The good news is that the belt looks okay, we don't need to replace it." "It should be okay, it's a brand new belt." "No, I mean it does not look like it was damaged." "I know. It's a new belt. I just replaced it. As in the previous belt was destroyed so I changed it for a new JD belt and when that did not work, I brought it here." "Well, okay. Anyway, the technician tested it and it's running fine now." So I load it up and bring it home. Fired her up and guess what. Same thing. There is some serious cooking going on in the block. There is white smoke coming from the air filter. She gets so hot, when you shut her down, it diesels for about two minutes. Almost as if there is no oil in it at all. (yes, the reservoir is full and the oil is fresh) The only thing (I know of) that changed was the voltage regulator, that was swapped out as the old one was not putting out up to spec. My gut tells me it is not in the mower deck. I suspect the tensioning attachment on the front of tractor. Maybe the PTO itself. When it is cool (just starting up) it cuts fine, like new, no bind. If there was any binding in the deck itself, you should pick up on that right away. It is also entirely possible that we are dealing with a 33 year old tractor and that the engine just is past its prime, as in will not put out the RPM or does not have the horse power to drive the mower anymore. Anybody have any pearls of wisdom? Thanks, PIII
