2020 6v coil, please explain
iwlbcnu
08-07-2006 08:29:27
Been fighting with running issues for awhile, went to replace the coil again and was told to try a 6v coil, and it fixed all problems. Why would a 12v system take a 6v coil?
jdemaris
08-07-2006 18:09:42
 Re: It's the Deere engine design in reply to iwlbcnu, 08-07-2006 08:29:27
There's a little more to it then what has been posted - in regard to your 2020. Generally speaking, there is no such thing as a purely 6 volt or 12 volt coil. If, let's say a tractor company wants 100,000 volts at peak ignition output - it can do so with 6 (4.5 at cranking) volts or 12 (9 at cranking) volts, it just takes a different amount of wire-windings. Keep in mind also, that a 12 volt system only provides around 9 volts when cranking, whereas a 6 volt system even less. And yes, there are many ways of lowering voltage to a coil after the engine gets started, in order to extend the life of the ignition points. Some resistors are fixed resistance, some thermally reactive, and some systems don't use them at all. Some 12 volt systmems, e.g. Ford, allow full 12 volts on demand when needed, even with a warm engine.
With the situation of many Deere gas engines other than the two-cylinders - mostly built after 1960 - conventional or generic replacement coils usually do not work well. That is because the Deere gas engines require more voltage than the average gas engine. If they don't get it, they tend to skip and/or break-up under certain conditions, and also will not start cold. It has ALWAYS been a problem - right from the start with the 1010 gassers. They were designed to use the same coil as the two-cylinder 6 volt 420. The coil worked fine, but even with the OEM resistor, they burned points something awful. With several new machines, we experimented with other coils with less output and draw - but it usually resulted in poor running and cold starting. This same problem persisted with the later 1020s, 2020s, 350 crawlers, etc. The OEM coil is the best route to go if you are using breaker ignition. If you convert to breakerless, and upgrade the high-tension wires, you can use even a higher output coil.
machinery-man
08-07-2006 09:03:19
 Re: 2020 6v coil, please explain in reply to iwlbcnu, 08-07-2006 08:29:27
This is voltage common on points. You will need to have an external resistor block or a coil with internal resistor. I might suggest electronic ignition to you, believe Genessee Electronics sells such a kit and you want have to mess with points or condensor again. I"ve used on several tractors and it solves starting running plug fouling problems.
Bob
08-07-2006 09:02:16
Because there is a ballast resistor in the circuit. During cranking, the resistor is bypassed by a special terminal on the starter solenoid, which gives a HOT spark from the 6-Volt coil while the battery's voltage is being pulled down to 7 to 9 Volts.
IWLBCNU
08-07-2006 10:15:03
 Re: 2020 6v coil, please explain in reply to Bob, 08-07-2006 09:02:16
I understand the dropped voltage because of the points, but why wouldn't you still use a 12v coil on a 12v system? Seems like it would burn up a 6v coil as it maintains 9v while running. Just seems like a mismatch of parts.
Problem we were having was w/ the 12v coil it would start misfiring after about 10 mins.
Duane Larson
08-07-2006 13:33:40
 Re: 2020 6v coil, please explain in reply to IWLBCNU, 08-07-2006 10:15:03
iwlbcnu,
This scheme is called "bypass starting" and was first used by Deere on some LP 60, 70 models, and adopted for the 20 series and later. As noted by others here, a 12V battery operating a 12V coil can be short on voltage to the coil primary during cold weather when the starter may draw 3-4 volts. Instead, a 6V coil is used with the 12V battery, together with a bypass switch and a ballast resistor. When the tractor starter is being operated the bypass resistor is dropped out of the circuit and the (12V - starting voltage) is applied to the coil primary, ensuring a high voltage output at the secondary to the distributor and plugs. As soon as the starter button is released the bypass resistor comes back in the circuit and drops the input voltage to the coil to a nominal 6V.
Your 2020 should have a ballast resistor, which drops the input to your 12V coil to a nominal 6V, and after the coil comes up to operating temperature in general the HV output often drops a bit, and with only half the designed input voltage the output voltage was not adequate to spark the plugs under compression.
This concept was also used in some cars from the late 50's till more modern systems came into use.
