JD 50 Water Pump
Chuck McDonald
08-07-2006 06:31:22
Good monday morning,
I finally got the radiator off the 50 last night and guess what I found. Surprise, surprise.....I also need a new water pump because the bearing is worn in mine!
So what I was wondering is, what is the size of the pulley on these pumps? Its a '55 JD 50.
Thanks
Chuck
Jack in Ohio
08-07-2006 06:52:16
 Re: JD 50 Water Pump in reply to Chuck McDonald, 08-07-2006 06:31:22
My '55 JD 50 has a 3/8" pulley on it. I just got a new belt for it and it was a 3/8" belt. I think the earlier ones had 1/2". Does yours have power steering? Mine does and I need to remove my radiator. I suppose I have to remove the complete worm drive unit of the steering to get the radiator out.
Jack
Chuck McDonald
08-07-2006 07:46:02
 Re: JD 50 Water Pump in reply to Jack in Ohio, 08-07-2006 06:52:16
Jack,
To get the rad out, you need to remove the four bolts that hold the PS unit to the Sector gear on the pedistal. I suggest marking the unit in relationship to the pedistal housing because you will need to adjust it upon reinstallation to make your PS center correctly.
Chuck
machinery-man
08-07-2006 09:21:34
 Re: JD 50 Water Pump in reply to Chuck McDonald, 08-07-2006 07:46:02
Deere had those rebuild kits. Bearing seal, clips. The key is taking you unit to press to remove pully. They are easily broken with regular pully, you need a backing collar clamp. They're not had to rebuild. Good luck.
