1949 John Deere A jumping under a load
Scott Griffith
08-07-2006 04:16:42
My A is jumping when under a load. When the engine fires it jerks the whole tractor and acts as if it is going to shut off. It does this through the complete throttle range in the same gear. My B, for instance, will run and pop smoothly under a load. Should I check the throttle linkage for correct position or timing? I have gone through and completely cleaned the carb from top to bottom and it is spotless. Could it be an idle or load needle setting? I generally set those to the point that the tractor quits smoking black smoke and does not surge at idle. What would be some good items to check for?
buckeye al
08-07-2006 15:32:02
 Re: 1949 John Deere A jumping under a load in reply to Scott Griffith, 08-07-2006 04:16:42
Check the proper adjustment and operation of the governor and all linkages!
First and foremost, the throttle MUST (absolutely must) rotate freely. I don't mean with "a little effort". I mean so effortlessly you can turn it with a feather!
I have seen after market re-build kits come with a rubber seal (or too big a felt) for installation at the top of the throttle shaft to keep dirt out cause this problem.
I have seen after market throttle shafts have the throttle plate slot in the shaft be milled too wide for the plate so that when you tighten the throttle plate screws, the shaft warps & binds in the carb body. With the screws loose it was efortless. Tighten them up & it would turn too hard. Not hard but way too hard for the sensitivity of the governor system! (Shim stock fixed that one.)
What you describe is very typical of a binding throttle shaft or linkage. I'll bet as you watch the throttle it goes from total shut down to WOT and back and forth. What it's doing is the bind prevents a little bit of throttle change (only what's needed) from taking place. The bind (wherever it is) keeps the throttle from moving until a lot of pressure finally moves it in a big jerk to wide open. At this point the engine responds with more power than is needed and because of the bind it goes into an over speed situation. When the governor finally gets it shut down, again because of the bind, it misses a couple cycles and now is running too slow again and it jerks to WOT. They'll do this endlessly!
It's a lot like pulling a stuck pulley or bearing off of a shaft with a wheel puller. It doesn't move as you tighten ever more until finally it moves in a jerk & stops 'till you tighten that hard again. Only real difference is that unlike the pulley or bearing, the throttle needs to move back and forth but it for some reason doesn't want to move either way freely.
Go find the bind & adjust it properly and I suspect it will behave much better.
Good luck.
Scott Griffith
08-07-2006 17:56:23
 Re: 1949 John Deere A jumping under a load in reply to buckeye al, 08-07-2006 15:32:02
I re-adjusted the throttle linkage as it was off by about 1/4 of an inch and the tractor performed much better. It still tries to lurch when in high gear going down the road at times but seems to be normal otherwise. I really need to put it under a constant load in low gear to see how it acts. Thanks to you fellas for the advice.
Scott
RalphinWI
08-07-2006 08:24:06
Is it running on one cylinder? Try shorting or disconecting one plug wire at a time. Second might be to check the compression for each cylinder.
Scott Griffith
08-07-2006 09:11:29
 Re: 1949 John Deere A jumping under a load in reply to RalphinWI, 08-07-2006 08:24:06
I tried to richen it a bit to see if it was too lean on the load needle side but that didnt help any. Would a lean mixture cause it to lurch forward like it is doing?
Scott
