?Proper Lubricant to Install Differential
Ken Reese
12-08-1999 06:35:46
What type of grease or other lubricant should I use in installing the differential and transmission in my 1950 model B? The manual says to lubricate pinions, shafts and bearing before assembly.
Ken Reese
E-mail: [email protected]
BIG SWEDE
12-08-1999 10:36:51
 Re: ?Proper Lubricant to Install Differential in reply to Ken Reese, 12-08-1999 06:35:46
Whatever lubricant you're going to use in the transmisson/rearend should be just fine. Once you have reassembled roll assembly over several tlmes so oil is carried to and covers all areas, gears, bearings etc.
RonMC
12-10-1999 23:06:11
 Re: Re: ?Proper Lubricant to Install Differential in reply to BIG SWEDE, 12-08-1999 10:36:51
It's a little sticky, but good gear assembly lube, and that's STP. When I used to do a lot of truck/auto diffs, we used it all the time. Dip the bearings, gears, etc, and they're guaranteed to turn over nicely.
