B narrowest tread setting?
wddave
08-06-2006 19:24:07
What is the narrowest tread setting with stamped center wheels? It looks like the bolts to pull back clamp need quite a bit of room so the inner part of the axle spline can't actually be used? Planning the pull the newly restored model 44 plow at plow day in a couple of weeks and would like to set the furrow wheel in pretty close.
johndeereman
08-07-2006 16:35:32
 Re: B narrowest tread setting? in reply to wddave, 08-06-2006 19:24:07
i have a 43 jdb with pressed steel wheels one wheel is all the way out the other is all the way in and it is 6"3" wide if you are good with a wrench you can run the hub right up to thehousingim guessing that i could move the other wheel in abvout 2" that would be abot 4"3" hope this helps also would make a difference if you have over sized tires
Brendon
08-07-2006 03:58:07
According to the manual for my '50 B, the rear wheel tread setting is 56-88 inches. I do not know if the adjustment range is different for the various wheel styles but I would guess that they would all be similar.
