Front End Loader Will Not Tilt
Ricky in NC
08-06-2006 11:11:46
John Deer 40 HP Tractor front bucket loader will not tilt. Hydraulics seem to be working OK..No leaks bucket will go up and down. The jaws of the 4 in 1 bucket open and close OK...Bucket is tilted to full down and will not tilt up...Any one had a problem like this. Any suggestions will be apreciated.
mechanic mikey
10-29-2006 12:32:54
 Re: Front End Loader Will Not Tilt in reply to Ricky in NC, 08-06-2006 11:11:46
Loosen hoses one at a time ,out at the tilt cyls. & move valve control to see if you're getting oil to it. Just barely bump control,if it's working you'll know it.
Ricky in NC
08-07-2006 11:47:08
The tractor is a 4500 the loader is a 460 model with a 4n1 bucket. The hydraulic lines move a little like it is getting hydraulic oil pressure but the bucket won't move. I suspect I need to remove the hydraulic cylinders and take them to a dealer for a rebuild. I am sure that will be good for the old pocket book. I looked at the valve underneath and etc. Didn't find anything lose or disconected. Thanks
cannonball
08-07-2006 03:18:34
you did not say what loader.. had a 175 do that and it had quick connects under the valves, one had popped out..some times more information helps... MAY GOD BLESS THE USA
amo
08-06-2006 17:12:53
try reversing the hoses to see if the cylinder is bad.
