4020D torque spec
deerechaser
08-06-2006 06:19:31
does anyone happen to know the torque spec on the cylinder head bolts and the valve specs for the 4020 diesel (1966)
thanks
I Bleed Green
08-06-2006 15:18:22
 Re: 4020D torque spec in reply to deerechaser, 08-06-2006 06:19:31
Head bolts 115 ft-lbs. They must be retorqued when engine is hot. Rocker arm shaft clamps 55 ft-lbs torque. (Make sure that the roll pin in the head lines up with the spring pin hole on the shaft) Valve clearance, Intake 0.018 in. Exhaust 0.018 in.
