620
big vern
08-06-2006 05:27:23
620 converted from generator to alternator....alt is not charging according to amp meter guage....does anyone have a wiring diagram that they could e-mail me ??? Open to any suggestions for solution of problem.
Glen in TX
08-06-2006 09:35:23
 Re: 620 in reply to big vern, 08-06-2006 05:27:23
First of all it's your tractor and use what you want on it, alternator or generator. Many of the CP don't even know how to polarize their generator and keep it charging anyway. The alternator can be a lot less trouble on a working tractor. I suppose you got the Delco 10SI a common alternator used in conversions. It should be putting out 12.5-14.5 volts at battery. Another easy way to check for charging is see if you got a magnetic pull on rear bearing by putting something metal on there while running like screwdriver or pliers. Original wiring diagram in the SM2029 is only going to show how to wire it with a generator but does also show some dash and lights wiring that may help. Difference in wiring if you have gas/all fuel or LP also. Email me if you need that or your JD dealer may have the SM2029 Electrical service manual or you can order it from JD,>Link
>Link >Link
>Link
machinery-man
08-06-2006 06:37:27
Personally I wouldn"t see any need for conversion. The later model hi output generator is adequate to maintain good charge levels. Depending on which alternator, there is need for a key switch(contact circuit), removal of the other type wiring. Personally can"t see doing this.
