1972 JD 4020 low hours worth
Mark A. Westpha
08-05-2006 22:23:35
I just bought a JD 4020, 72 model, synchro and the seller claims it to have only 3400 hours original.
They say that it is a factory hour meter and the meter still works.
Is there any way to tell if this is the same hour meter that came with the tractor and if it still works could this actually be the true hours on the unit.
I will be using this tractor in a haying operation.
What would this tractor be worth. 2 remotes Very straight tin.
Thanks,
Mark
Romey
08-07-2006 15:41:53
 Re: 1972 JD 4020 low hours worth in reply to Mark A. Westphal, 08-05-2006 22:23:35
My neighbor just sold a 1968 4020 with 8000 hrs. It was a pampered, 2 owner tractor. Original paint and excellent condition. $13,000. I live in N.E. Iowa. The 4020 market is always good around here.
RalphinWI
08-06-2006 19:52:06
I know of a 4020 gas c.a. 3000 hrs, clutch pedal serations show essentially no wear, and it appears to have the original Goodyear tires. I assume the Serial Numbers on the tire could be checked for age.
960
08-06-2006 12:20:13
In my area of midwest a 7000 hr. clean 71 or 72 will bring $12-14,000 at farm close out auction. Two years ago a 2000 hr. 72 brought $24,000 at a consignment sale.
Ray
08-06-2006 09:24:55
The last 3000 hour 1972 model 4020 i saw on an auction brought $23000.A 1970 model with 3900 hours sold in ohio for $17000.
Mark A. Westphal
08-06-2006 08:44:39
Link
Actually, this link posted above will show the exact tack guage.
Mark
uoflncolts
08-06-2006 14:26:40
 Re: 1972 JD 4020 low hours worth in reply to Mark A. Westphal, 08-06-2006 08:44:39
I believe that your tach shows the 20 instead of the 2000. It could be the very tach that was put on in the factory.
Ryan
Mark A. Westphal
08-06-2006 16:32:28
 Re: 1972 JD 4020 low hours worth in reply to uoflncolts, 08-06-2006 14:26:40
Thanks, I think so too! My first impression was the wrong one.
Mark
Mark A. Westphal
08-06-2006 07:16:20
I will check those things when I go pick it up.
Thanks,
Mark
uoflncolts
08-06-2006 04:26:33
Does the tach say 2000 RPM or 20 RPM(then at the bottom it says times 100)?
Ryan
Mark A. Westphal
08-06-2006 07:14:42
 Re: 1972 JD 4020 low hours worth in reply to uoflncolts, 08-06-2006 04:26:33
It says 2000 RPM.
uoflncolts
08-06-2006 08:18:45
 Re: 1972 JD 4020 low hours worth in reply to Mark A. Westphal, 08-06-2006 07:14:42
Somebody correct me if I am wrong, but I think the 4 digit RPM was a replacement for the factory 2 digit. I am 99% sure that your tach has been switched.
Ryan
MSM
08-06-2006 03:42:27
With out actually seeing the tractor the hours could or couldn't be correct.It could very well have the original clock in it and actually be 3400 hrs.Has it been to a local dealer for service,they might have some records.You would have to look at the rest of the tractor. Is the tach cable original?Is the drawbar worn down or the hole egg shaped,how sloppy are the lift arms,are the steps and pedals worn,how are the shifter gates and shifter,console top and levers?
If it is indeed a 3400 hr tractor and has excellent cosmetics and rubber,it should be worth in the $10k range,maybe more.
