John Deere 60
Josh B
08-05-2006 13:00:33
Recently purchased a late 1954 Model 60 John Deere. I have some previous knowledge of old Deere's, but I have run into a problem I can't figure out. Tractor didn't run when I bought it. Cleaned the rotor, cap, and point contacts. All replaced before I bought it and appear new. Both plugs have good spark. The tractor cranked after cleaning the cap and rotor, but ran smooth for a minute and then almost died and then ran smooth, so on and so forth. I could unplug the flywheel side plug wire and it didn't affect the running at all. I broke down the carb. and cleaned it thoroughly. Fuel bowl (sight glass) was also cleaned top to bottom. Tractor still presented with the same problem as before. Takes a while to start it and then runs horribly. Know it will not even start. Could it be a timing problem. The previous owner claimed it ran before he parked it, so I don't really think the timing could be off. Any suggestions? Thanks!
Jerry Olson
08-06-2006 10:09:22
 Re: John Deere 60 in reply to Josh B, 08-05-2006 13:00:33
I also have a model 60 and had a similiar problem. I found the fuel line from the gas tank to the glass bowl was plugged with sediment. I unscrewed the bowl assembly from the tank and blew it out from below the tank (after draining the tank) and now it runs like a top. Check it out!
Glen in TX
08-05-2006 13:17:27
You may have plugged passage ways in the carb, poor fuel flow, bad carb float, plugged air cleaner (mud dauber, dirt & grease from 60 years) ?? Try running it with the air cleaner loose. Are the plugs black and sooted or clean or wet fouled? Operators manual or a I&T manual will tell you how to check the timing.
Josh B
08-05-2006 16:53:28
 Re: John Deere 60 in reply to Glen in TX, 08-05-2006 13:17:27
Yeah the I&T manual is my next option. The plugs have been mainly black and sooty. The intake has good pressure when the engine is trying to start, but I figures I might have to really check it and go over the carb again anyway. I feel pretty confident I cleaned every possible nook and cranny in the carb, but I will go over it again. it's a pretty safe bet since the tractor had been sitting up for a while befroe I bought it. Heck, it only cost 500 and it looks great. Just need to make it run. Thanks so much for the help.
Bob
08-05-2006 13:03:13
Did you see the post, several posts down, about the 50 only running on one? There's good suggestions there.
Josh B
08-05-2006 16:49:06
 Re: John Deere 60 in reply to Bob, 08-05-2006 13:03:13
Yeah I did. Thanks for the suggestion.
