4630 pto
WELBY
08-03-2006 14:04:11
I have a JD 4630 with turbo intercooled diesel and powershift trans. The pto runs constantly and will not shut off. The pto lever does not lock into place on disengage or engage position. I disconnected the lever from the pto valve body and moved the pto pin coming out of the valvebody by hand with no resistance going to disengaged position and resistance going into the engaged position. When pushed towards the engaged position, I heard a small grind noise when resistance started and then the noised stopped as i kept moving the pin. When I released the pin, it sprung back to middle position. Help if you can.
Glen in TX
08-04-2006 14:15:53
 Re: 4630 pto in reply to WELBY, 08-03-2006 14:04:11
Sounds like you need to fix the lever, spring and cable linkage first. View parts catalog at JD Parts online.
Welby
08-07-2006 07:44:15
 Re: 4630 pto in reply to Glen in TX, 08-04-2006 14:15:53
Thanks,I was wondering if a spring could be messed up on the disengage side of the pto valve. I will replace spring and let you know if that was it. I talked to the local John Deere dealer who said they thought it would probably be the pto brake. I hope that it isn"t. That would mean the tractor would have to be split apart and then about $3000.00 later repaired.
