Pushrod tubes again
ARS
08-03-2006 10:56:06
people say they use all-thread and another piece of pipe to pull out the old pushrod tubes, and i understand what they mean. what i need to know is what size all-thread to use? what if it doesnt come put using this procedure? its a '44 JD B
Lynard
08-03-2006 17:48:30
 Re: Pushrod tubes again in reply to ARS, 08-03-2006 10:56:06
ARS I did one years ago and I think it was a fine thread 3/4. Instead of buying an all-thread use a bolt and a piece of pipe and add washers as it pulls out. Lynn
Mike M
08-03-2006 11:42:55
I used what ever I had laying around that I could weld to a nipple. I think I only had 3/8"
ARS
08-03-2006 17:16:05
 Re: Pushrod tubes again in reply to Mike M, 08-03-2006 11:42:55
well, it couldnt have been 3/8" because the inside diameter of the tube is alot bigger than that. its about 5/8", or maybe a hair bigger. maybe im not completely understanding how to do it...
jc37A
08-03-2006 19:30:55
 Re: Pushrod tubes again in reply to ARS, 08-03-2006 17:16:05
third party image
I replaced the tubes on my '37 A a couple of months ago. I used a 5/8" coarse thread tap to thread the tubes and a piece of 5/8" all thread to remove them. I removed the tubes without taking the head off. I was surprised at how thin the metal had become as you may be able to see where the all thread went through part of one of the tubes. I have not run the tractor since the install but plan to in the next couple of weeks. Hope this helps!
Duane Larson
08-03-2006 18:01:14
ARS,
I believe Mike M was using a 3/8 NPT pipe tap - that would be about right. Then he welds a piece of all-thread (any size) to a 3/8" pipe nipple and threads the pipe nipple into the brass tube he just tapped. Then slide a piece of pipe over the nipple/all-thread large enough that the brass tube will fit inside, put a washer and nut over the top of the pipe, and tighten the nut to pull the brass tube.
I think Mike said there is nothing special about the 3/8" pipe tap - just happened to be what he had that fit to make threads in the brass tube - just use a tap which gives threads inside the brass tube, weld the all-thread to a bolt which fits the tap, and do as above. But make sure your tap is not too large so it cuts thru the brass and damages the head.
Mike M
08-04-2006 05:13:34
 Re: Pushrod tubes again in reply to Duane Larson, 08-03-2006 18:01:14
You got it exactly right,that's how I did it.
I think I used the pipe tap because it seemed to fit the best and they are tapered so they start easier and then the piece I screwed into it held tighter as well. I did mine right on the tractor.
John T
08-03-2006 11:33:57
Im unsure of the all thread size, but guess if that fails to extract them youre left with pulling the head and using the proper size bushing drivers. I could have swore my unstyled B pushrod tubes were slightly larger on the inside head side (why we had to remove head to remove n reinstall) but its been a while or maybe your styled is different??
Sorry not much help on this one, been toooo long
John T
JDAOS
08-03-2006 12:10:42
 Re: Pushrod tubes again in reply to John T, 08-03-2006 11:33:57
The push rod tubes are larger on the valve cover side and must be installed from that side.
