Might it be easiest to tell him "yes the MAGNETO makes a spark every 180 degrees BUT, the distributor part of the magneto sorts out the sparks. The distributor sends one out this wire every 360 degrees. It sends one out that wire every 360 degrees too but the one out that wire is always a half turn behind this wire's spark." Since the pistons are 180 degrees apart, this wire has to go here & that one there so that we have a match. My Dad was a high school Chemistry and Physics teacher and he believed if words didn't explain it, then a little experiment & your own observations might. Here's the kind of thing he might have done had I not understood the mag beter than he did. Remove the plugs & show him the cycles of the engine. Next have him lean against the tractor holding the left or #1 plug in his left hand and the #2 or right plug in his right. AS you roll the crank to #1 TDC he might have a better understanding of the why, where and when right after the click. I bet it won't take a second click! He might still not understand but what he now knows, he won't forget! {:-)
