3010 pto seal leak/broken bolt
Superp
08-02-2006 14:58:41
I had oil leaking out around the bottom of the pto stub shaft of a 3010. I went to the dealer and have a new gasket for the housing and a new seal for the housing also.
While taking off the stub shaft of my newly acquired tractor, the four bolts came out very easily. Each one had a small hole through and the pairs had a small wire twisted through them (figure eight)to keep them from working loose I suppose. One bolt I took out appears to have been broken off in the threads of the shaft (not the stub shaft). There is about a 1/4 in of bolt threaded in there.
Any good ideas on getting this broke off bolt out without hurting the threads of the shaft. I am hoping someone here has encountered something like this before. I keep hearing bad things about ez-outs.
Bob
08-02-2006 22:36:04
 Re: 3010 pto seal leak/broken bolt in reply to Superp, 08-02-2006 14:58:41
Start by attempting to drill the bolt with a left-hand drill bit.
With a little luck, the bit will "catch" the bolt, and back it out, without the need to complete drilling the hole, or attempting to use a screw extractor.
TimS
08-03-2006 08:58:20
 Re: 3010 pto seal leak/broken bolt in reply to Bob, 08-02-2006 22:36:04
Try the left handed drill bit, some PBBLASTER or other lubricant, if you do drill a hole and try an easyout or bolt extractor, don't use much force on it, or they will snap and leave you with a piece of very hard metal in the center and you will be worse off than before....
