1952 JD A Clutch
T Wall
08-02-2006 12:07:10
I have a 1952 JD A and the clutch makes alot of noise when its engaged pulling a mower. It's quite engaged just idling. Could this be the clutch bearing? Any help would be appericated.
buckeye al
08-02-2006 13:52:36
 Re: 1952 JD A Clutch in reply to T Wall, 08-02-2006 12:07:10
Maybe the clutch's driver disk is loose on the crankshaft?
Hope not but if in the early stages of its life of looseness (which is real short) they can make a hammering or pounding noise when under light loads yet be quiet most o the time.
At least check it out & make sure!
T Wall
08-03-2006 07:14:41
 Re: 1952 JD A Clutch in reply to buckeye al, 08-02-2006 13:52:36
The clutch drive disk will not go all the way up on the crankshaft. It likes about 1/4 inch, but it's not loose. The casting number on the drive disk is correct. The center bolt holds it tight.
Mike M
08-02-2006 13:05:29
The outer most R.H. trans. input bearing is located behind a small 2 bolt cover on the reduction cover this is farther back to the rear from the belt pulley you should see it. Take that cover off and see if any bearing is left. This is a very common problem and maybe it will quiet it down some if yours is shot.
