G lower water pump pipe
KJF470
08-01-2006 18:43:21
Would anyone happen to know the diameter of the lower water pipe on a 1951 G with a water pump! And does the lower water neck (head side) and the water pump take an o-ring or a square cut quad ring. Thanks in advance.
Miller49G
08-02-2006 04:37:30
 Re: G lower water pump pipe in reply to KJF470, 08-01-2006 18:43:21
The OD on the pipe is 1 7/8 and it is 14 11/16 long. And it takes an O-ring on both ends to seal it.
KJF470
08-02-2006 08:53:47
 Re: G lower water pump pipe in reply to Miller49G, 08-02-2006 04:37:30
Thanks for the help. I was able to put the old one in a vise and flatten it enough to just twist it out of the water neck.
