JD 4230 rockshaft dropped suddenly
Cas
08-01-2006 12:42:36
I run a 200 gallon sprayer on the 42 and a couple of days ago the 3 pt dropped to the ground suddenly in the field. The tank was loaded. I assumed that the oring blew out on the piston but I was wondering if anything else could cause such a sudden drop. I have never had one do that before. No work has been done on the rockshaft so nothing could have been changed. The lift will pick up about 3 inches at the bottom, with or without load, it makes no difference. This makes me think it could be something other than catastrophic oring failure.
charlesmm
08-08-2006 00:05:54
 Re: JD 4230 rockshaft dropped suddenly in reply to Cas, 08-01-2006 12:42:36
If you are still there....,try raising the rockshaft and listen for oil hissing /spraying internally . remove the filler neck and with a flashlight look for an oil mist .I doubt that you would lose the seal so fast , usually they leak down faster and faster, I think it's a prob . in the control ,let me know if you are still reading this stuff!
charlesmm
08-02-2006 23:42:44
Nobody else is helping so here goes... I don't have the manual here but are you getting 2300 psi at remotes ,if no gage then are remotes lifting something heavy? check priority valve and thermal relief valve try max min lever in all positions , is lever on rockshaft obstructed?
some things to try to begin with.
Cas
08-03-2006 07:24:12
 Re: JD 4230 rockshaft dropped suddenly in reply to charlesmm, 08-02-2006 23:42:44
Hi, thanks. The pressure is good at the outlets. So far everything checks ok but no lift. Something isn't quite right but I have never seen one with a blown oring. It seems it would raise the arms with no load even if it is blown but I could be wrong. We are using the tech manual and going step by step but it seems we are chasing our tails now. It is tempting to go ahead and pop the piston out to see once and for all.
