Coulter
Retired 05 in V
08-01-2006 09:53:46
Just purchased a 1949 John Deere M. A two-way plow came with the tractor, but one coulter is missing. The only identification marking is G757-A on the front/top of the plow support. Any help in locating a coulter is most appreciated.
jd51mt
08-02-2006 05:25:34
 Re: Coulter in reply to Retired 05 in VA, 08-01-2006 09:53:46
Retired,
Sounds like maybe you have a M-3-B one-bottom 2-way moldboard plow. E-mail me and I can send you a picture of it.
MIke
johns48b
08-01-2006 19:29:36
try to identify the model number of the plow. you may be able to find a part no. on something and a good parts guy can tell you every item that part was used on and then go through his old parts books and you should be able to id the plow and then find a part number for the coulter. if your just going to use it and not restore it you should be able to find just any coulter that will work. good luck
