Follow-up for BuickDeere and HTR of 7-31-06 or any
Larry 2809C
08-01-2006 07:57:09
Thanks for your help, we now have the gear shift cover off, but do not see any bent or broken parts. The gears are all locked up and it appears that the majority are back in the housing towards the rear of the tractor. I have tried to slide, turn the gears to no avail. Do I need to take more of the case towards the rear of the tractor off. I am lost at this time, and would appreciate any help.
Mike M
08-01-2006 10:51:07
 Re: Follow-up for BuickDeere and HTR of 7-31-06 or in reply to Larry 2809C, 08-01-2006 07:57:09
I went back and saw you were having trouble with a model 2030. I think you will find these are a collar shift transmission. Meaning the gears are always in mesh with another gear and there is just a collar that slides back and forth locking the gears to the shaft.So I'd say you need to make sure all the collars are centered to neutral.Jack up the back and see if anything turns ?
Glen in TX
08-01-2006 09:54:54
Jack one or both rear wheels up and see if differential is locked up or if trans is stuck in 2 gears at once. Also make sure the clutch fork didn't come apart locking into gears in the reduction gear cover on clutch side.
Larry 2809C
08-01-2006 11:33:46
 Re: Follow-up for BuickDeere and HTR of 7-31-06 or in reply to Glen in TX, 08-01-2006 09:54:54
Thanks again for the response and suggestions: We tried to rock the tractor and then tried to pull the tractor with another tractor, and the rear wheels just slide. It is locked up tight, but dont know if its transmission or rear end. I suspect its the tranny as the gears were getting difficult to shift just before lock up..thanks again for your help Larry
K.B.-826
08-01-2006 19:46:35
 Re: Follow-up for BuickDeere and HTR of 7-31-06 or in reply to Larry 2809C, 08-01-2006 11:33:46
You might be able to get a better look by removing the rockshaft housing.
