jd toplink
jwill
08-01-2006 03:05:33
On the 60 the top link is two arms with a piece of metal with a hole in the center. How do I use this as I would the top link on a ford?
Brent in WI
08-01-2006 20:10:56
 Re: jd toplink in reply to jwill, 08-01-2006 03:05:33
Check out the pictures on this link. There is one album with an 800 converted to 3 pt.
http://public.fotki.com/deanvp/hitches/jd/800_series-1/
Mike M
08-01-2006 07:15:33
I have had real good luck getting most things hooked up to one by removing that cross bar and then find a long enough bolt or pin so you can place the eyes of the yolks on the OUTSIDES of the uprights and just leave a gap in the middle where you normally put a normal top link. This also takes out all the side sway too.
