RPM ADJUSTMENT ON A
JDJACK
07-31-2006 19:29:12
I have a JD 44 A. How do I increase the rpms? lengthen or shorten the rod between the carb and gov or between the gov and handle? Also what is fast idle spec for this tractor?
Mike Aylward
08-01-2006 06:06:58
 Re: RPM ADJUSTMENT ON A in reply to JDJACK, 07-31-2006 19:29:12
JDJack, once the governor to carburetor rod is set under no circumstances should it ever be disturbed, unless the carburetor is removed and a new gasket installed or some other thing that would disturb the geometry of the adjustment. To adjust this rod open up the throttle lever (engine off) and disconnect the rod from the governor to the carburetor (either end). While holding the carburetor wide open the rod should lack "one-half hole" of reaching the hole where it is installed (I always set them a full hole short which makes them a little more throttle responsive). Once this is set, leave it alone. THEN, adjust the bolt on the steering post to the correct RPM level. There is not a big advantage on these tractors to having them running in an overspeed condition. Most times they will come down to rated speed quickly anyway because of the equilibrium established by the governor spring/governor weights. Many folks just start changing adjustments on these tractors without knowing what they do. This should get you started. Mike
Pappy
07-31-2006 19:55:44
You would shorten the rods to increase speed. Absolute maximum engine speed with no load is 1080 RPM.
