G Choking itself/ flooding.... HELP
Ben.So.Tex.
07-31-2006 19:10:11
The choke handle on my 49 G started coming back by itself and flooding itself out.
It does not have a choke rod. It has been running fine with a minor miss which sounds like a leaking valve. Help me if you can. Thanks Ben
Duane Larson
08-01-2006 08:40:18
 Re: G Choking itself/ flooding.... HELP in reply to Ben.So.Tex., 07-31-2006 19:10:11
Ben,
Check the link below for a pix of the choke system on your DLTX51 carb. It sounds like the spring may be broken - it provides a friction action between the choke lever and carb body to keep the choke lever from moving.
Super Lurker
08-01-2006 08:31:28
A friend's '36A would do like that. He ended up wireing a spring to the choke handle and over to the breather pipe to keep his open. Choke would still work, but wouldn't close itself off and flood the motor.
