1950 John Deere B`
IowaFarmall
07-31-2006 18:26:19
Hello All! I have aquired a 1950 John Deere B. This tractor has always had a keyed ignition and I was told it was an option started in 1950. Many 50' models I have seen do not have this option on them. My question is, is this uncommon or are there more out there than I think. The research done on my tractor states there were no special features/attachments from the factory.
johnlobb
08-01-2006 16:00:49
 Re: 1950 John Deere B` in reply to IowaFarmall, 07-31-2006 18:26:19
My 1950 JD B does not have key start. It does have a Wico X magneto. I read that around this time Deere started using distributers and coils but if you wanted a magneto it was a no cost option. John L.
MLD
08-01-2006 05:16:27
Our 52 was bought new by grandfather, dad said it had a key ignition switch when new.When the switch went bad it was replaced with a standard "push/pull" type switch.
IowaFarmall
07-31-2006 20:29:54
It does have a Delco Distributer. Was magneto or distributer an option? I know it has always had the switch because the original owner said it came new that way.
CLW
07-31-2006 22:35:27
 Re: 1950 John Deere B` in reply to IowaFarmall, 07-31-2006 20:29:54
The B used a Wico type C Magneto from serial number 201000-217798. From 217799-268820 the Wico Type X was used. At 268820 the Wico XD Distributor became standard equipment but you could still order a magento if you wanted. Many Wico distributors were later replaced with Delco-Remy units. This is from TWO-CYLINDER magazine, May-June 1998.
Pappy
07-31-2006 20:00:14
If your tractor has a Delco or Wico Distributor, it would likely have a keyed ignition switch. If it is equipped with a magneto, it would not, but would have a kill switch on the magneto, which might be wired to a grounding switch on the dash.
Olivergreen
07-31-2006 19:27:00
My 1950 A has key ignition. Its indak like lawn mowers. Proably retrofit to replace a bad in out switch. My 2 cents worth.
