john deere 200 disc tiller
bruce schepler
07-31-2006 15:08:38
needing help setting a 200a disc tiller. it does not want to stay in the ground. it goes for a while then wanders behind the tractor. any ideas. thanks/bruce
Tx Jim
08-01-2006 03:31:59
 Re: john deere 200 disc tiller in reply to bruce schepler, 07-31-2006 15:08:38
It"s been many years since I adjusted a disc tiller. I think yours has a soft/hard ground setting and is yours set fo.r hard? Set front of tiller slightly higher out of ground than rear. Does yours have rear wheel weights? Tx Jim
johns48b
07-31-2006 18:57:52
i have the same problem. i found that the ground was just so blame hard that it was causing my turning plow with disk on it to run up and out of the ground. you might try catching it after a rainif its not to wet. if you can take a hand full of dirt and wade it up in your hand and make a mud ball its to wet. if it crumbles its ok to work. i have slowed my ground speed down and that helps to. if you solve this problem please post back.
