24t baler
Wil Thomas
07-31-2006 14:04:06
Question for all you hay makers... " I aint one, "YET " Knotter problems. After some adjustments " Very Small" & general grease & oil & clean up and so on. Knotter is still malfunctioning. I noticed that the twine is not following the needle in the groove, but rather, running off the side of the needle. Is the twine supposed to follow the needle in the groove of the needle ? Preciate any help. Wil
Roger in Iowa
08-01-2006 07:28:25
 Re: 24t baler in reply to Wil Thomas, 07-31-2006 14:04:06
The twine has to follow the groove in the needle. Is the porcelain guide not in line with the needle or does the groove have some material in it keeping the twine from being in the right place?
Roger in Iowa
johns48b
07-31-2006 19:05:01
i had an ih baler that would miss bales real bad if you didn't keep the dust out from under the knotters. also check the drive gears to see if the are worn real bad on the sides that have the flats on them. clean all the teeth out on all the gears and don't put grease on them. does your bill hooks have a lot of wear on them on the top? get the manual and look to see if there is a section that describes what to do for your problem. an old ih mechanic once told me if it ain't working right get off and twist something. if it gets worse go back the other way.
mjbrown
07-31-2006 17:46:38
The needles have to get the twine up close enough to the billhooks so they grab it when they start to turn on the tie cycle. The book will tell you how close they need to be . I don't have one so can't help with the spec. But everything has to be set right to run good. When they are they hardly ever miss.
old
07-31-2006 15:06:33
If you haven't done so yet you need to go see a JD dealer and get the manual for that baler, yep they still have them. Cost around $30 and will help you more thne you know. As far as the twine you know I have never watch if it goes to the side of in the middle when the needles come up. But the big thing isn't that but that the tucker fingers put the twine in the right place at the right time and the bill hooks do what they should at the right time which by the way the book tels you and also they have a trouble shooting guide in them. Now if you have the book you can disregaurd a lot of what I just said
